Montañes by Occre Build Log
I started to build the masts.
I decided built the bowsprit first. But I faced a problem.
In Turkey we were ordered to stay at home from 9 pm to 5 am for weekdays and for weekends (from friday 9 pm friday to monday 5 am). It's active for last 7 weeks and noone knows when it'll end. So I decided to move some of my tool to home and converted my computer dest to a small workshop. (Yes of-course I got permission from my wife :) ) But couldnt take my lathe to home.
I decided to use my drill as lathe to make bowsprit parts. What I did here is to sand by hand gently to thinner the wood. I used 80 grit sandpaper first and than 150, 240 and finally 400. Result was satisfying.
View attachment 206787View attachment 206788View attachment 206789
Problem solved and bowsprit came to shape.
I used brass black solution for brass strips ans simply glue them to their places. I glued all three parts together and tie down with 0.5mm brown thread.
I made two metal parts from 1 mm coper wire ( Sorry I dont know their names. If someone tell me I'l be very pleased :) )
I forged the edges of the parts and shaped them, solder the edges of the ring after mounting the pieces and used brass black solutionfor to give iron effect.
View attachment 206792View attachment 206793View attachment 206794View attachment 206795View attachment 206796View attachment 206797View attachment 206798View attachment 206799
Finally I tied down the blocks.
View attachment 206803View attachment 206804View attachment 206805View attachment 206806View attachment 206807View attachment 206809
Hallo Bilal,
great and very good work of your rigging - especially your self made hooks are very good.
I realized a (maybe) small mistake in the installation of the blocks - so maybe you could check the orientation of the blocks (oriantation of the holes)
Hallo Bilal,
Thanks for your encouraging comments Uwek.
That drawing at the picture is top view.
Side view drawing is much more clear.
I think he is saying the block with the blue arrow is facing the wrong way, the hole should be on the opposite side. Otherwise your line is coming from the bottom of the block. Hope that makes sense. You could always just hand drill a hole on the correct side. ;)
Sorry Understood at last. :)
I'll correct it tonight.
The WWII Eisenhower admonition of the landing plan on D-Day "The devil is in the details" carries over to precise rigging. Good encouraging critiques being given and received here without rancor which is a positive side of SoS for the vast majority. Just a thought. Rich (PT-2)
You’re absolutely right sir.
In my opinion that’s what these logs for.I appreciate all SOS members who warns my mistakes.
Ship modelling is a huge ocean and all of us have lots of questions about it whether as a newbee or as a proffesional modeller.
BTW mission completed. :)
Nicely tied off. Well done which will make moving forward much easier. Rich
Photo was taken just after varnishing. Shining will fade as the varnish dries.
Here are some photos after varnish dried.
4.jpg7.jpg141788204_2734686256841441_5845274198761915982_n.jpg142475284_2734686346841432_2541297219563097198_n.jpg
After this process I started to rigging.
First I installed the bowsprit. Checked the aligment first and then tie down necesarry ropes to install fore mast lower section.
After bowsprit installement. Before gluing, I wanted to check the position of fore mast. I used three temporary ropes to do this. And then glued.IMG_3348.JPGIMG_3350.JPGIMG_3349.JPG
And then begun to prepare the shrouds. There are nine shrouds on each side. So I prepared 8 double and 2 single shrouds.
Shrouds installed to the mast one to the right and one to the left, respectively
141980409_2734686586841408_1187380856633770485_n.jpg142277613_2734686303508103_2575649219053473456_n.jpg142128979_2734686140174786_8015251775438784359_n.jpg142128988_2734686356841431_125442590467543571_n.jpg
And then I checked the orientation of the ropes just under the crow's nest as picture below. 141946964_2734686293508104_5106950032726393823_n.jpgIMG_3384.JPG.
Now It's time to tie them up. Fist I installed the support rope (I dont know the technical term in english sorry.) Then begun to tie down the dead eyes. I didnt use any template for deadeyes. Also sorry because I forgot to take photos how I managed this process bu will do with the main mast.
141880179_2734686086841458_6071377558645501094_n.jpg142687004_2734686590174741_2344598655700891682_n.jpg
And then two ratlines for warm up and finished for now. I dont use any template for ratlines also. Up to me every shrouds and ratlines unique for each model and using a template is useless for good quality work.
Finally my quality control team checked the model.
And yes the brown lady was the manager of QC team. Please take a look at her way of looking. :)
Best Regards from Turkey.
Hi Bilal.
You have installed the shrouds already and I have to tell you that the prow ones are wrapped as well as the others in their closest part to the crosstrees.
I'll try to find some pictures...
Sorry
Hi Jaime
I have only this drawing from OCCRE and it's A4 size.
And I installed the rope which marked with green arrow to support the fore mast
If I did something wrong I want to correct it.
I'm waiting your pictures.
Thanks in advance.
Best Regards.
Hi Jaime
Thanks in advance.
Best Regards.
You are progressing well and I am confident that you will have a pleasing finish ship to view. Rich
Good morning Bilal.
At least I could find the pictures of my build. Is the San Juan Nepomuceno that is not exactly the same type of ship (The Montañés was more modern and better) but in this special feature, I think, were the same.
The wrapping or the threads were made in order to protect them from extreme friction or tension. Thats the reason why the prow shrouds were covered, to prevent them from being severely frictioned by the yards coming up and down and from the continous beating of the sails. In the same way, the stays were also wrapped, because were in high tension, provided they support the stability of the masts.
Besides all the shrouds were wrapped in the part they embrace the masts, just in the crosstrees and until the futtocks.
I show you all of this in some images.
Please let me know if there is something you want me to explain further.
Greetings and good job.
Jaime
PD. The instruction manual is very simple, all of this is an improvement of the model that will make it unique.IMG_1829.JPG
See the prow shroud wrapped
Detail
The shrouds supporting the masts. That part is also wrapped.
Wrapped until the futtocks.
Main stay and preventer stay, wrapped.
General view.
