     As a way to introduce our brass coins to the community, we will raffle off a free coin during the month of August. Follow link ABOVE for instructions for entering.  |
Hallo Bilal,I started to build the masts.
I decided built the bowsprit first. But I faced a problem.
In Turkey we were ordered to stay at home from 9 pm to 5 am for weekdays and for weekends (from friday 9 pm friday to monday 5 am). It's active for last 7 weeks and noone knows when it'll end. So I decided to move some of my tool to home and converted my computer dest to a small workshop. (Yes of-course I got permission from my wife) But couldnt take my lathe to home.
I decided to use my drill as lathe to make bowsprit parts. What I did here is to sand by hand gently to thinner the wood. I used 80 grit sandpaper first and than 150, 240 and finally 400. Result was satisfying.
View attachment 206787View attachment 206788View attachment 206789
Problem solved and bowsprit came to shape.
I used brass black solution for brass strips ans simply glue them to their places. I glued all three parts together and tie down with 0.5mm brown thread.
I made two metal parts from 1 mm coper wire ( Sorry I dont know their names. If someone tell me I'l be very pleased)
I forged the edges of the parts and shaped them, solder the edges of the ring after mounting the pieces and used brass black solutionfor to give iron effect.
View attachment 206792View attachment 206793View attachment 206794View attachment 206795View attachment 206796View attachment 206797View attachment 206798View attachment 206799
Finally I tied down the blocks.
View attachment 206803View attachment 206804View attachment 206805View attachment 206806View attachment 206807View attachment 206809
Hallo Bilal,
great and very good work of your rigging - especially your self made hooks are very good.
I realized a (maybe) small mistake in the installation of the blocks - so maybe you could check the orientation of the blocks (oriantation of the holes)
Thanks for your comment Mustafa.Veery good work Bilal Bey. Congratulations and thank you for sharing your excellent build on here. I am learning a lot.
But isn´t the block with blue arrow in the wrong direction?Thanks for your encouraging comments Uwek.
That drawing at the picture is top view.
Side view drawing is much more clear.
I think he is saying the block with the blue arrow is facing the wrong way, the hole should be on the opposite side. Otherwise your line is coming from the bottom of the block. Hope that makes sense. You could always just hand drill a hole on the correct side.Thanks for your encouraging comments Uwek.
Sorry Understood at last.But isn´t the block with blue arrow in the wrong direction?
The WWII Eisenhower admonition of the landing plan on D-Day "The devil is in the details" carries over to precise rigging. Good encouraging critiques being given and received here without rancor which is a positive side of SoS for the vast majority. Just a thought. Rich (PT-2)Sorry Understood at last.
I'll correct it tonight.
You’re absolutely right sir.The WWII Eisenhower admonition of the landing plan on D-Day "The devil is in the details" carries over to precise rigging. Good encouraging critiques being given and received here without rancor which is a positive side of SoS for the vast majority. Just a thought. Rich (PT-2)
Nicely tied off. Well done which will make moving forward much easier. RichYou’re absolutely right sir.
In my opinion that’s what these logs for.I appreciate all SOS members who warns my mistakes.
Ship modelling is a huge ocean and all of us have lots of questions about it whether as a newbee or as a proffesional modeller.
BTW mission completed.
Wow! Fantastic Bilal.A little progress last night.
I didnt want to use supplied base plates for crows nest. So I did my own. Finally fore mast lower piece completed.
View attachment 207585View attachment 207586View attachment 207587View attachment 207588View attachment 207589View attachment 207590View attachment 207591View attachment 207592View attachment 207593View attachment 207594View attachment 207595View attachment 207596View attachment 207597View attachment 207598View attachment 207599
Thanks Paul.Wow! Fantastic Bilal.
You have produced an excellent substitute for your build. RichThanks Paul.![]()
Thanks for your comment Rich.You have produced an excellent substitute for your build. Rich
Hi Bilal.
You have installed the shrouds already and I have to tell you that the prow ones are wrapped as well as the others in their closest part to the crosstrees.
I'll try to find some pictures...
Sorry
You are progressing well and I am confident that you will have a pleasing finish ship to view. RichHi Jaime
I have only this drawing from OCCRE and it's A4 size.
And I installed the rope which marked with green arrow to support the fore mast
If I did something wrong I want to correct it.
I'm waiting your pictures.
Thanks in advance.
Best Regards.
