Wow. You have embarked on a mammoth project ... BUT ... the first 15 frames look excellent! With those under your belt, you will have the confidence to tackle the rest. Well done Ron!
Thank you for the compliments Heinrich and JimskyGreat to see you back posting, Ronald. BTW, you have really nice progress. Keep yem coming!
Hi Ronald. Why didn’t find your build-log earlierTime for a small update..., just some pictures...
So far the frames are only sanded based on the drawing. After fixing all the frames to the keel it need further sanding...
15 frames done, 55 to go....
These frames looks very nice.
it's looks great progress,As we approach the end of the year, I thought it would be nice to take a short look back at the realization of this model....
On June 6, I started making the construction plank, after which I immediately started with the keel. I made the keel twice because the first time went wrong when applying the notch. Fitting the 'bolts' into the frames seemed to go well until it was pointed out to me that I was using the wrong pattern, I stopped doing this after three frames (don't know if I'll be making them again for this reason). Blackening the brass 'bolts' after they were installed in the frames seemed to go quite well. However, over time I do see some effect of the patina on the surrounding wood, not sure if I will continue with this. In any case, do not think about investing further in installing the pins, as they will not be visible or will hardly be visible.
After making an x number of frames, I did something else, namely an attempt to make a figurehead... Nice attempt, but went wrong...
Which has also been discussed about the necessity of whether or not to completely manufacture the frames, since this model has an open side. Opinions are divided on this.... I think there are different methods that eventually work, but it is clear that precautions must be taken....
What I finally decided to do is complete the frames and decide later which pieces to remove. The reason is that I don't want to fix myself on where the openings will be located yet, I want to have the space later to be able to use all the possibilities. That is why I first work on a complete hull...
Obviously, creating frames is a lot easier than "future challenges...
Status now is that of the 65 frames (ex bow and stern) I have now completed 27... In more than six months time, I think that is an acceptable result, see photos...
It now remains for me to wish everyone a good end and a prosperous but above all healthy 2022, and that our hobby will provide everyone with many fun hours..![]()
Grazie per i complimenti! Mi mantiene motivato per il prossimo frame
Volevo un piccolo intermezzo tra le cornici, quindi ho pensato di provare a fare un soprammobile... Qui potete vedere un esempio di come non si dovrebbe fare un soprammobile....
Poiché era solo pratica, ho usato un pezzo di quercia. Prima ho fresato i contorni utilizzando la mia fresatrice, poi ho provato ad aggiungere alcuni dettagli con la mia fresatrice manuale...
Quando ho visto con quale risultato ho lavorato ho rinunciato al tentativo... Non ridere troppo quando guardi le foto....:fresco:
Lo so già... Non usare la quercia, e non iniziare con un ornamento questo complesso...
Ed è così che dovrebbe essere....
