- Dec 11, 2021
Thank you Peter! I'm following you, because you are the Magister Magno!
**VIEW THREAD HERE** |
Now you sound like a true manager!Thanks Johan! I hope to finish the BN for the summer time but .... there is a BUT for everything! I didn't say which year ....
A hull with 'some color' looks always better! Like Johan said: You did (so farToday's update:
a coat of transparent base paint was applied to close the small cracks on the plank of both sides.
Then a good coat of sanding to remove the excess of base coat and make the surface as smooth as possible.
Then I applied a first coat of red on the starboard side half and ...
a coat of linseed oil on the port side and frames.
Wonderful work - she is looking great!
Looking very nice, PierroToday's update:
I have finished painting the hull.
I also decided to paint the part with the visible frames in black because I like it more and because I can insert the decorations and the plaque with the name on this side as well.
I made the rudder as for Peter's technique ...
See you later!
I feel flattered ……I made the rudder as for Peter's technique ...
She is looking good Piero! I know about that frenzy…ha ha! When you have momentum, it is hard to stop!!Thanks Johan for your nice replay!
If you remember, as I said at the beginning, I wanted to finish this build by the summer. Even with the interruption of a couple of weeks to build my Canoe, I have regained the right rhythm.
You know what, when you see that your work responds well, then you are taken by the "frenzy" to go on as much as possible ... Then the evening comes and you also have to rest a bit ...
This happens when I'm at my home here in Italy since there is no possibility to do anything else ....
Good progress Piero! Enjoy your time off!Thanks Dean!
For all my Friends, the latest weekly update. All the stuffs assembled and glued very quickly because they have already been made previously.
Now a weekend of rest, with an excursion to the Rocca di Angera on Lake Maggiore with very rich local lunches and dinners ...
Ad Maiora Vertite!
