Difficult to explain, but I give it a try.Hi Stephan,
Looking at position 17 I see you are at more or less the centre frame( the "hals" of the hull)
In that case I think your floor is not flat enough. From the keel up the garboard should be at an +/- 45 deg. angle and the following floor planks at ships centre should have a very slight angle creating a more or less flat floor up to the planks at the bilge. I am afraid with your current floor you don t get the hull shape you are aiming for.
I have sketched it below, garboard in blue, floor in yellow and bilge in purple.
If you fill the hull now with floor timbers they will all need a high curvature or a filler piece as you see on English frames. In Dutch ships you don t see this.
See below the shell of Willem Barentz and you see the floor timbers are nearly straight, even for this jacht with its sleek hull design.
Hi Stephan. I was going to ask you how and what you measured in the construction of the hull to ensure there was symmetry between Port and Starboard sides, but you've answered that in your last updates.On the Dutch forum there where some concerns about the shape of the hull because of the minor anomalies on the surface of the floor.
I think about to adjust the shape on the red part to get rid of the hollow form that seems to appear in the hull
For the hull shape this is not a big problem, it is a small part in the hull that is influence by this. And I think not vissible went corrected in the right way. We see what happened, I have no concerns about it.
You have to let go of the mindset in this build of I have to follow the drawings exactly. You have to think here more about building a hull that has flowing shapes, no kinks, cavities that are overdone, as well as bulges. Also, you should not expect than starboard and port sides are the same. You are building a Dutchman, there this was not important. I only use the drawings to get the size and whether I am in the right direction since I decided to do shell first. I find a deviation of 1 to 6 mm acceptable depending of course on which point of the ship. Is it very visible or is it actually not noticeable. This deviation is not going to be noticeable considering what part of the ship it is. How small that part is of the entire hull.
The green area and the blue circle show the part on the ship.
And if you look at the museum model, it appears that its builder wasn't looking too closely either.
Thanks Nigel.Hi Stephan
I can’t help but think the issue you have is that your planks are glued solid edge to edge whereas the original had wooden “links” nailed across the top between planks allowing the builder a great deal of flexibility allowing him to pull the first stage of planking to the floor timbers when they are fitted
I would not disregard what you have done already if you decide the shape is incorrect.I would at least attempt thoroughly wetting the planks and try clamping the structure down to a flat surface using some temporary forms on the inside.
Kind Regards
Nigel
thanks Ken, your words helped me to go on. Yes these Dutch ships where not that symetrical on port and star. Maybe the big case the Vasa sunkLooking at the museum model and the difference between both sides of the hull, I can't help but think that if the actual ship had this hull profile it would list to the Starboard. Maybe there is something I'm not aware of that mitigates this?
In any case, your work is unquestionably good and I am not surprised. Keep it up.![]()
.True storyIt’s amazing what you do, Stephan. And then there are model builders who say that PoB of PoF plankings is difficult……..
This is next-level-planking!
I know some fine templates: we call them frames………I learned a lot of the mistakes I did in the beginning, so let avoid them this time and do the things right. First I go think about the template, how to.
funny guyI know some fine templates: we call them frames………
Here we called it ‘een inkoppertje’ ……funny guy![]()
I saw this coming...Too many small imperfections and one far too large on the back were the reason for this major redo of the hull. In a second I had decided to remove all the planks. That was a lot easier then attach them.
I just got the keel and stem clean again and we will start from scratch later.
View attachment 371306View attachment 371307View attachment 371308
Whether it will be the Maze I don't know yet, the shell first suits me. (Sorry Maarten I still need them) But then with a template to get the shape right. Freehand is too heavy on small imperfections and warping of the planks so the shape can't be maintained with each course you place.
Exactly, imperfections is a word that perfectionists cannot deal withI saw this coming...
Hi Stephan,Too many small imperfections and one far too large on the back were the reason for this major redo of the hull. In a second I had decided to remove all the planks. That was a lot easier then attach them.
And I have to start al over again. Another keel, stern and bow is needed. The HZ model having a lot of angels in the decoration. And my admiral loves angels, so she will not forgive me when I change plans.Build the 7P?
Just kidding, if you have set your mind to build the Hohenzollern model it would feel like giving up.
