- Oct 21, 2022
So far, today has been pretty successful dealing with serving and adding shrouds.
I have completed the shrouds (including the swifters) for the main lower mast.
One of the things I've noticed is that the Rope of Scale, while highly detailed in its look is actually hard to serve! The cabling is so aggressive that when I serve it, it looks like it's being wormed. I have to be very attentive while serving to be sure it looks right.
You can see from the finished work that some of the serving looks better than others. I thought about doing a quick pass to kind of work the rope and then dragging the serving line back to the beginning and then serve it....
Either way, the shrouds seemed to lay down nicely on the mast. Sometimes the seizing would stick to the shrouds and make it hard to slide up, but I was usually able to pick and turn the seizes to get them right.
You can see above that I clearly made the jeer strops too long, but I was able to get all of the shrouds under them. Whew!
The only thing remaining here would be to add the jeer strops and over that would be the 2 stays.
I may or may not create the jeers and then move on to the fore mast.
All in all, I am actually happy with the work. I was and remain VERY nervous about this stage of the build. So much is foreign to me and a lot the instructions and terminology is so vague that I sometimes get 'stage fright' when I'm in the shop.
But today's results have been very encouraging and as a beginner I will tell others that get to this point, this portion of the build has been a breeze and very satisfying!
