- Oct 21, 2022
I began two separate tasks, the installation of the lower deck cannons and the beginning of the long process of ratlining!
There are two different length cannons for the lower decks, the longer for the bottom row and shorter ones above.
I used a 1.9mm drill bit to drill the holes. I was hoping I could create a block of wood to insert in the cannon voids. But my work in adding the liners didn't quite make them all consistent. I was able to create a long 12x12mm block and after a few tries was able to drill a hole through the center that actually came out on the other end in the center! I should have just clamped it and used my drill press, but I did it free hand.
I then drilled the holes as close to the center as I could. I placed all the cannons in and they appear to be pretty good.
I then blackened all of the cannons with Birchwood Blackening. I added about 12 cannons in and let them soak for about 3-5 minutes. I would then take them out and let them dry on a paper towel for a bit and then give them a second dunking. After that, I put them on toothpicks to dry. They may need a bit of touchup with my black iron paint.
I was able to glue them in place with CA glue and once done with the yards, I'll circle back and begin the lids.
I may do them before, it will depend on what kind of tangle the rigging will create!
