H.M.S. Victory by Caldercraft - Build Log
I began two separate tasks, the installation of the lower deck cannons and the beginning of the long process of ratlining!
There are two different length cannons for the lower decks, the longer for the bottom row and shorter ones above.
I used a 1.9mm drill bit to drill the holes. I was hoping I could create a block of wood to insert in the cannon voids. But my work in adding the liners didn't quite make them all consistent. I was able to create a long 12x12mm block and after a few tries was able to drill a hole through the center that actually came out on the other end in the center! I should have just clamped it and used my drill press, but I did it free hand.
I then drilled the holes as close to the center as I could. I placed all the cannons in and they appear to be pretty good.
I then blackened all of the cannons with Birchwood Blackening. I added about 12 cannons in and let them soak for about 3-5 minutes. I would then take them out and let them dry on a paper towel for a bit and then give them a second dunking. After that, I put them on toothpicks to dry. They may need a bit of touchup with my black iron paint.
I was able to glue them in place with CA glue and once done with the yards, I'll circle back and begin the lids.
I may do them before, it will depend on what kind of tangle the rigging will create!
My next or concurrent task was to begin the ratlines.
I used plan sheet 12 and traced the shrouds and ratlines on paper. I had to darken some of the lines on the plan to see them through the paper. I did this for the lower, futtock and upper shrouds. I believe that all I will have to do is reverse them and redraw the lines for the other side....we shall see!
I pinned the template to the foremast lower shroud and began tying the ratlines. There was a learning curve to tying the clove hitches, but once I got it, they go pretty quickly. The directions suggest leaving the end tails until after you use watered down white glue to secure the ratlines, I didn't do that, cutting them all of so they wouldn't get in the way. I'll leave the white glue till I'm down with a whole mast and make sure the lines are pretty even.
I did have some trouble with the lowest ratlines as I rigged the deadeyes a bit too high and the cleats and tied off shrouds interfere with those lower lines. I added them the best I could. Again, I'll rely on the taller sailors to climb the rigging!
View attachment 505503View attachment 505504
Beautiful work
Thanks for all the stop bys, comments, likes and more! They mean a lot that folks actually take the time keep up on other builders!!!!
Been working slowly on the rat lines. It's a slow process and ironically, it's hard on my back. A lot of the work is high up even with a better work table and there is a lot of strain. Who knew model work was tough!!!!!
I have the futtock and upper ratlines for the mizzen mast starboard side left. Probably 3 hours or so of work, then on to the other side.
Hopefully thought, the weather is going to start getting better up here in west NY so I can start getting my sailboat ready for the summer. It hasn't been very good yet, mostly rain, snow or just cold and dreary. At some point the model will just kind of sit to the side until this September. Don't hate me!!!!!
Nice progress and very neat work
Hey there!
Well, summer is almost done here and I'll be putting one sailboat away and getting the other one out!
I'll have to take some time to see where I was and what I was planning next!
I did have the pleasure of visiting the VOC Amsterdam in Amsterdam last week. What a beautiful ship and I couldn't stop smiling as I looked at the full scale rigging, wales, gun ports, bits and more and know just what was what!
I will see you all soon!
Chris
Well, I have finished the ratlines on the starboard side. I had to spend an hour cleaning up my shop that had turned into a dumping ground for all the end results of my summer projects. Bits and pieces of wood, foam, dust. It was a mess, but the upside is that after sweeping I found three deadeyes that I had dropped! Hopefully I can still use them!
All I had were the upper ratlines of the starboard mizzen mast to finish the side, but first I had to watch a video to re-familiarize myself with how to tie ratlines. It came back pretty quickly. Ironically, the upper ratlines are the hardest. These are obviously high up on the boat and even though I tip the model towards me (I put a 2x4 under the port side of the stand), it becomes tiring. The very last 3 have little room to work the lines and tweezers and standing helped.
They're done now, at a glance, not bad. Some dips there and there, but they'll blend in.
Still have a month or so of fall work around the house until I can spend quality time on the model!
This fall we did a great river cruise on the Rhine River. We ended the trip in Amsterdam and while doing a canal sightseeing trip, I saw a tall ship in the distance. Looking it up, I saw that it was the VOC Amsterdam. A replica of an West India cargo ship from the 1750's.
I loved looking at many of the various apsects of the ship and smiling to myself as I thought...yeah, I built that too!!!!
Loved to see the worming and serving up close, if only my attempts were that good!!!!
Some wide shots of the lower platforms.
Loved the real image of the hearts used to attach one of the stays!
We will be in Amsterdam for several days next summer before and after a cruise to Scotland and Ireland. We plan to visit the Anne Frank Museum, Van Gogh Museum and the Rijksmuseum. Would you recommend visiting the ship if we have time? We can add a day or so to the stay in Amsterdam if needed.
Thanks Chris
Thanks Chris
Allan;
If you have time after visiting all the other 'must sees' in Amsterdam, I would recommend the VOC Amsterdam. There aren't a lot of options to see tall ships in the Northeast so I was very impressed with the ship. While not as big as the Victory, but it is of the same era and I enjoyed seeing the real life construction detail that I've been working on at scale! I think you could spend about 1-2 hours looking through the ship which allows you to go all the way down to the lower hold under the orlop deck
I would tell you to book your tickets to Anne Frank's house as soon as they allow you to. It books up VERY quickly, not sure about the other 2. The VOC is huge and that won't be an issue.
Chris, where did you find your hammock netting? I've looked everywhere.
I found it on Amazon at https://www.amazon.com/dp/B01M060A0P?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1
I had bought 2 other types on Amazon, they were rolls of 6" tulle. One was ivory and the other was apricot. They were ok, but very difficult to work with.
The fabric I finally found was cotton instead of a poly and was nice. You do have to be very careful when cutting it, otherwise you'll cut into the next row and it becomes harder to sew onto the rails. Overall, I liked the look and color and if you want, you can stain it with tea or some other dye and it will get darker.
I did that to test but opted to just use the color it came with.
EDIT: I was looking at your build and I see that you are at about the same point as me. Well, you're a bit further along, as you've done the cannon lids and I see you've begun adding the yards. So, no, you're WAY ahead of me!!!!
You'll have a bit of a chore adding the hammock netting now, as you'll have all of the shrouds, stays and yards to compete with. But, I see you opted for the alternative poop deck setup, so you can opt not to try and place netting there?
I added the netting before putting the masts in place, so I was able to get my fat fingers and arms where I needed them to sew.
....I've already knocked the cat's heads off on both sides as I did the foremast ratlines....
You're model looks great by the way. Very nice!
Hi Chris
Thanks for the link
Thanks Chris. I like the look of your netting so I'll give this a try. Did you wrap both sides and base as well or just the sides?
The netting covers the sides and base. I placed a larger piece into the hammock racks and used dowels or stir sticks to keep the bottom of the netting in place as I sewed each side. Once I had a side done, I was able to cut the extra away and then do the other side.
If I recall, I did the inside netting first and allowed the outer side to hang over. I used clothespins to add weight and keep the netting tight.
Hi Chris. I remember doing those nettings. I found them very fiddly and this was not my favourite job on my Victory. You have done a fine job with these. Cheers Grant
