Bomb Ketch Salamandre 1:48
I secure this to the bed of the milling table using a double layer of double-sided tape (of course you can use hardware if the slots line up).
As long as I'm spending your money buy a small digital angle finder and impress yourself with your new accurate milling.
Already have the digital angle scale...love it! Any more suggestions on spending my money, let me know ROTF
Brad take it from my experience and a pile of rejected hawse timbers - normal double sided tape wont hold with more powerful mill like a sherline or taig. I use this one with success and left behind the frustration.
Thanks, I will give that a try!
Isopropyl alcohol will usually release the tape with the added benefit that it won't raise the grain in the wood. We do it all the time in the furniture industry.
Awesome, I have a bottle of that, so will give it a try.
Again, appreciate the advice from those with much more experience and ideas than I have!
Trash bin swallowed my first set of Cant frames:(!
Seems this is not an uncommon occurrence!
I milled the bottom on some (or all of them) too narrow. The remaining space was too wide for one Cant frame to fill.
I hope I understand the drawings and angles better so my second attempt will be successful!
The new adjustable angle milling table will help immensely too!!
Good morning Brad. Eish and a true story. I think cant frames even with kit models have redo written all over them. There is a reason why they are called cant frames as we just "cant" get them right ROTF . Cheers Grant
Cant Frame trials and tribulations. ROTF
Long post that may help someone attempting the complex curves on this particular bow.
Some obvious things, after 22 days studying all the intricate drawings for these complex 3D curves:
1. The six Cant Frames have no spacers, so each angle has to be milled perfectly to interface with the next (see photos from a builds' I often reference, by Alexandru Gurau and Jimmy on this forum).
2. The angles for milling the Cant frames (Red Arrow in frame 4 below) need to be measured and milled with extreme accuracy. After measuring: ENSURE THE SUM OF THE ANGELS = 90 degrees! Seems obvious now…Duh!?!? On my first attempt the angels added up to 83 degrees! This left me with a gap that could not be filled.
2. Use the outside of the lines (blue arrow on frame 5 above) to measure the thickness of each Cant frame, then add 2-3 hundredths of an inch to each frame “for insurance”. Hindsight on the first attempt I measured to the middle of each line.
These two cumulative errors resulted in my last Cant frame being too narrow to fill the space in the picture below.
THE SUCCESSFUL ATTEMPT:
1. All six angles added up to 90 degrees. Beer
2. I added 3/100 of an inch to the measured thickness of each frame.Beer
3. On initial test fits, things were too tight. After sanding each frame fit tightly.Beer The inspector showed and gave a thumbs up BUT he berated LTJG Newbie for taking 20 days to do 6 frames. :mad:
4. A good set of Cabinet scrapers are you friend as you try to fair these complex curves.
5. An accurate tilting table for you mill is also you friend! I attached a wood “working base”, using the tape CBL recommended.
6. Finally, two perspectives of the unusual bow curves. It actually bends backwards, making for some very complex angels. Sanding, scraping and fairing this area will take some time and patience!!
4-days (12-14 hour) fairing the interior port bow section.
The below photo shows the significant and complex curvature. It also shows the multiple curved cabinet scrapers, and flexible home-made sanding sticks that were critical in fairing them. Now to make the Starboard side a mirrored duplicate!!
This next two photos show the significant tumblehome, typical of French construction of this time period. This widens the hull at the waterline. This would make the mortars more stable, during the long-range sieges where they were employed.
In the evenings the shipyard has been producing bolts that will be used to secure the keelson over the frames.
The process:
1. 20-gauge brass wire is cut into short lengths with fingernail clippers.
2. The wire is placed in a small drill bit vice, mounted in an electric drill. The base is narrowed (like a nail) with a file, then a small burnishing tool rounds and polishes the imitation bolt head.
3. Final photo shows three test bolts. They are set slightly proud of the surface, as they will be done on the keelson.
Progress, however slow, is still progress, right? Beer
Terrific, Brad! It's hard to remain patient during this processing of the inner hull and it seems you have managed quite nicely.
As I have now established a reputation for spending your money... The cup bur you showed works for a limited production, but you might have noticed it gets clogged up easily. If you ever need to increase your output and lower your frustration Busch offers another version that ejects the shavings very nicely:
Paul,
Still trying to spend "my money"...sure you're a dental profession and not in Government? :)
I didn't order the Busch cup burrs, as the set I have are working fine BUT:
When I went to your link, it also showed Gesswein® Lube-Stik
So of course I had to buy some. Should prolong the life of the burrs, even though the soft brass doesn't seem to dull them too much.
Nice work Brad !!!!
As my grand nephew would say, “damn, you da bomb!” Well done, Brad…
Thanks for the positive feedback.
Hello dear Brad, i hope you find this info useful. Once an outstanding Maitre Aleksand Dobrenko shsred his method of making nails with mushroomlike head from the Brass wire by knurling. The sharpened wird is cut by rolling it with a strong knife on a dense rubber base, such as a hockey puck. I used this method when working on my models, it works really well.
My very best regards, Aleksadr
Slowly scraping & sanding the interior frames. First half of the ship is 99% complete.
Soooo...I made an attempt at the stern port/starboard Cant frames. The Sherline mill made this fairly straightforward, but still time consuming. Results below: I'll point out the small errors that resulted in another addition to the scrap pile.
1. The shape angles and unsanded/unfaired lines were perfect.
2. Here is where the small mistakes are apparent:
a. Somehow, I cut the bottom of the Cant frames too short. I tried adding a small spacer but find the seam distracting,
b. The 1st perpendicular fashion piece I milled it with the grain fore and aft, vice perpendicular to the keel, like I believe it should be.
3. Bottom line...close but no cigar!
Brad - I re did this assembly probably a half dozen times on my build. Heres what worked for me. I added all the transom bars first and then fine tuned them for a flush fit with the fashion piece which was then installed.
If I had to build my ship again I would have completed both the bow assembly and stern assembly outside of the construction site on separate jigs. Maybe on the next build...
Keep up the good work !
