Obstacle course worked well...asleep before their lulliby tape was over!We had a great-grandson sleepover Friday. Love it, but boy, are we getting old. Great idea on the obstacle course - get 'em tired quickly.
Also wondering if you are quietly calling for help as some of your flags are upside down?
Good morning Brad. Definitely worth the redo. I’m so used to redo’s on my current ship it has become the expectedFour hours: the stern transoms and skewed stern frame are GONE!
I'm feeling better!!!
I cut through the transom pieces and brushed each joint with water, until I felt them loosen. Then a few seconds with the heat gun and they slipped apart. See photos below:
View attachment 563767 View attachment 563766
Here are the shots I was trying to get when I discovered the frame I somehow skewed.
Now she sits in a new building jig, with the offending frame dry-fit.
View attachment 563778View attachment 563779
Time to relax and watch Sunday Football games.
Reconstruction starts tomorrow.
Thanks everyone for encouraging me to tear apart the stern and "Get it Right"!! Not as hard as I anticipated.
. Cheers Grant
Brad, great idea using the rafter squares! Magic Mike4-hour to Demolition the stern. 4-days to Rebuild it AND construct two types of cradles.
The cradles may be interesting to new modelers, looking for ways to secure their hulls during construction.
The first cradle is simple. Cutout two profiles (frames 10 and 30 in this case). It allows the hull to be set down and picked up easily.
The second is made to hold the hull perfectly level and perpendicular. To build it, I bought 4 plastic rafter squares for $7 each at Home Depot. Aluminum were $15 each.
I then made some blue shavings with the mill! (I'll be finding blue shavings in the workshop for the next month)!
Combined with two strips of aluminum channel and Presto: an easy to secure jig for accurate and repeatable measurements. A half turn on the screws and they slide easily, releasing the model.
Pictures of the repaired transom frames, with the ship in the new jig to ensure everything is square and level. Amazon also delivered a 1/16" end mill. This small diameter made squaring the grooves for the counter timbers much easier.
View attachment 564693View attachment 564694
Next, I'll review a bunch of build logs and try to figure out what the next step should be. I feel I need some more longitudinal support before sanding and fairing the exterior. My thoughts:
1. Add the deck clamps and spacers, as shown on Oliviers Rochefort. I forgot to put in the spacers as I installed each frame.
2. Add a top longitudinal strip, like Chris Bren did on his Renommee.
Thanks for your continued interest as I work through the build (rebuild) sequence!!
Hi Brad,
I am worried with the varied weather conditions of winter and heating of a warp. I have not removed my ship from the build board but am instead adding the interior planking of the hold to give it even more rigidity before removing it from the jig.
Chris/Tobias, I too am worried about warping.I can only agree with Chris: leave your hull in the jig as long as possible. If possible, screw the keel to the bottom plate. I think Chris had a slight warping of about 1mm there. I had the same issue with my La Palme; I screwed the Le Rochefort keel in place and there was zero warping.
Cheap but effective.Brad, great idea using the rafter squares! Magic Mike
